Update: libflashplayer is installed on my system, firefox just isnt using it.... I discovered this hack-sawing through my root directory with ls -R / | grep libflashplayer
I want to disable the screensaver when watching videos online because when it activates and I move the mouse to escape it, my video is frozen fullscreen. Everything is still running, the screen just wont update and I have to use the sysReq key to force a shutdown.
Im not sure about the underlying problem (maybe I should file a bug report?) but I just want to prevent the screensaver as a quick fix.
I found this old topic How to prevent my screen from either dimming or the screen-lock starting when watching YouTube? and wanted to comment my question there, but alas I do not have the reputation.
Im using Ubuntu14.04 x64 with the flashplugin-installer.
I would like to use the script provided in that thread (its very simple and elegant) but it seems libflashplayer is not what is being used by my system. In fact not a single library with flash in the name is being used, hence grep flash /proc/$pid/maps returns nothing.
Any suggestions on what library firefox might be using to render flash content?
And please don't suggest using caffeine, it no longer supports flash and was terribly buggy anyway.
0x0byte
  • 143
Try using a different version of flash, it may fix your problem.
Here's a script that installs the latest version of pepper flash on firefox. It might fix your problem. https://db.tt/rHEJ2e0l
to run it, open terminal, cd into the location where the script is and install type:
chmod +x freshplayer_maintainer.sh; ./freshplayer_maintainer.sh
and the rest should be self explanatory
answerSeeker
  • 901
  • 26
