I installed pipelight and then executed this:
pipelight-plugin --system-check
The last lines of the output were:
libXrender.so.1: /usr/lib/x86_64-linux-gnu/libXrender.so.1
libxslt.so.1: /usr/lib/x86_64-linux-gnu/libxslt.so.1
libXxf86vm.so.1: /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1
Libraries: FAILURE
Where do I find an explanation or a log? Whats the next step?
givanse
  • 601
Not all of these libraries are necessary to use the plugins supported by Pipelight. You can find a list of really essential libraries at http://pipelight.net/cms/faqs/faq-libraries-missing.html
Some libraries are only required for very specific use cases like libnetapi.so which makes it possible for Wine to interact with Windows servers and Windows network shares. This is not used by any of the supported plugins and you do not need to care about it. There was also a bug report at https://bugs.launchpad.net/pipelight/+bug/1327518 to fix these remaining libraries and most of them should be fixed in the next release (except libnetapi.so which is not multiarch ready on Ubuntu yet).
Not sure if you are after a certain end-result. But I ran through a lot of problems with pipelight and in the end I was able to run:
wine-browser --no-pipelight --windowed
this runs firefox within wine, which seems to work fine.
amc
  • 7,292
JimB
  • 586
