When I wanted to upgrade from Ubuntu 13.10 to 14.04 the update manager told me that there was an unresolvable problem with calculating the upgrade. In order to see more details I performed the following on the command line:
apt-get update
apt-get upgrade
apt-get dist-upgrade
apt-get install update-manager-core
do-release-upgrade
Now do-release-upgrade tells me that no newer version is available but the "about" box in the main menu tells me I am still on 13.10. I think the latter is right, as for instance in the "system settings" there is no way to select local menus, which is present in 14.04 (I tried with a DVD, and there it is).
Maybe the problem is related to the fact that "apt-get update" cannot get two resources called "saucy/InRelease" and "saucy/main/binary-i386/Packages" from the mirror (mirror.informatik.uni-mannheim.de; 404 not found). I would like to use a different mirror; how can I do that?
Any help appreciated, thanks in advance.
NGRhodes
  • 9,680
To change your mirror there are 2 methods:
  1. Using System Settings > Software and Updates. On the main tab there is a drop down labeled "Download from:" and choose a mirror from that drop down.
  2. Edit the file /etc/apt/sources.list with root access e.g. from terminal:
    sudo nano /etc/apt/sources.list
    Once in there replace "http://mirror.informatik.uni-mannheim.de" with "http://archive.ubuntu.com/ubuntu" (to get the main Ubuntu repo), or you could pick one from the long list: https://launchpad.net/ubuntu/+archivemirrors
Then once done repeat the steps you listed in your question:
apt-get update
apt-get upgrade
do-release-upgrade
NGRhodes
  • 9,680
