Knowing file extensions really helps to understand what a program is doing or using. What are some common one's and how do I extract them?
File extension are up to the creator of the file. In Linux you can name something music.mp3 but if it is a text file it will open with gedit if that is your texteditor because it will look at the 1st bit/byte(?) where it says what kind of file it is.
When it comes to bash script it is considered best practise to not include .sh at the end. By omitting it you basically create a command so those do not tend to even have an extension. And those commands could be made in bash but also in perl or python.
So looking at the actual name of the file might be misleading!
Linux has a command file to find out what a file is. Syntax file *
Some random samples:
xxxx.sql: UTF-8 Unicode text, with very long lines
xxxx.sql.gz: gzip compressed data, was "xxxx.sql", from Unix, last modified:
Wed May 18 10:21:34 2011
yyyyy: ASCII text
iffffff: directory
ghgggg.tar: POSIX tar archive (GNU)
fhhfhf.pl: perl script text executable
For a list of extensions Fuddledumpy's post can be used and files ending on .pl will more than likely be perl scripts but to make sure use file.
- 309,379
Be aware that Linux doesn't care too much about file name extensions. It determines the file type based on the file's contents/MIME type, so knowing a file extension doesn't give too much insight into a program's usage pattern.
See What is the relationship between MIME types and File .extensions? and How are file-extensions/mime-types/icons/default applications associated? for more info.
Technically, the list of known file extensions is stored in /usr/share/mime/globs. Here's a copy with nicer formatting.
I'm not sure how to decide which file extensions are "common". This list claims to be "common" but I think I've only ever run across about five percent of it.
- 78,496
