When using Terminal Server Client, it is possible to access the Windows desktop (remote desktop), from an Ubuntu PC.
Is the reverse possible?
What is the Windows XP application used to connect to an Ubuntu desktop?
Is the default mstsc application sufficient? If yes, what are the required settings on Ubuntu and Windows?
I want to view the desktop, not just an SSH terminal access.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
AIB
  • 1,441
Yes, it is possible. You can use Teamviewer or VNC to do just that in a Windows system.
Steven
  • 867
I used Remote Desktop to connect to my Ubuntu box. xrdp on the Ubuntu box is an adequate rdp server.
Tips here on getting it working if you're having problems with nothing displaying (except the background).
lambda23
  • 3,362
you can try tightVNC . And it's a simple guide to use tightVNC. Hope this helps
neyz
  • 129
If you have XP Professional, one can also use Remmina remote Desktop Client on the Ubuntu side and just straight RDP to get to the XP machine. Simple VNC viewer will work in reverse. I always liked UltraVNC on the XP side.
Kendor
  • 4,928
