I want to use a "ReinerSCT Standard" Chipcard reader with the Jameica/Hibiscus Homebanking suite. I installed "pcsc-lite" and the "libifd-cyberjack6" package, and if I run
pcscd -d -f
I can see the card reader is discovered correctly and also detects when I insert or remove a chipcard.
However in Jameica, whatever I do the card reader is not found.
What am I missing?
Nodebody
  • 551
I solved the problem by creating the file
~/.jameica/cfg/de.willuhn.jameica.services.SysPropertyService.properties
and manually configuring the location of libpcsclite.so.1 in this file by adding the following line:
sun.security.smartcardio.library=/lib/x86_64-linux-gnu/libpcsclite.so.1
After restarting Jameica the reader was correctly found automatically and I can finally do all my homebanking using Linux.
You may also want to have a look at this page (German):
http://www.willuhn.de/wiki/doku.php?id=support:list:kartenleser
Nodebody
  • 551
