The problem is basically that Unity seems broken after an upgrade from 13.04 to 14.04 LTS on x64, so here goes:
1) The Unity logon screen looks strange - e.g. the user names are hardly legible due to poor contrast - but I can still use the screen to log on. The problem described below affects all users.
2) After logging on, the standard Ubuntu wallpaper appears "blank" with no panel and no launcher. There is simply "Ubuntu 14.04 LTS" in the bottom left, apparently carried over from the logon screen.
3) I can switch to the text terminal with Ctrl+Alt+F1.
4) There I did a series of fixes found online, such as:
rm -rf .compiz-1
dconf reset -f /org/compiz
setsid unity
unity-tweak-tool --reset-unity
export DISPLAY=:0
unity --reset-icons &disown
I also run ccsm and made sure the Unity plug-in and OpenGL are activated.
5) I can now start unity for the current session by entering the command unity, but I have to switch to the text terminal and enter unity every time I log on now.
6) The output from the "unity" command is as follows:
WARNING: no DISPLAY variable set, setting it to :0
stop: unknown job unity-panel-service
start: unknown job unity-panel-service
compiz (core) - Info: Loading plugin: core
compiz (core) - Info: Starting plugin: core
compiz (core) - Info: Loading plugin: ccp
compiz (core) - Info: Starting plugin: ccp
compigconfig - Info: Backend: gsettings
compigconfig - Info: Integration: true
compigconfig - Info: Profile: unity
compiz (core) - Info: Loading plugin: composite
compiz (core) - Info: Starting plugin: composite
compiz (core) - Info: Loading plugin: openg1
compiz (core) - Info: Starting plugin: openg1
compiz (core) - Info: Unity is full supported by your hardware
7) With Ctrl+Alt+F7 I can switch to the Unity session, where the launcher now works and the standard application icons appear down the left side. But the panel is completely empty. The windows all look kind of "old style" to me (I think).
Any help much appreciated!
Braiam
  • 69,112
user289372
  • 33
Try a clean install:
sudo apt-get update
sudo apt-get remove unity unity-2d unity-2d-panel unity-2d-spread unity-asset-pool unity-services unity-lens-files unity-lens-music unity-lens-applications gir1.2-unity-5.0 unity-common indicator-sound indicator-power indicator-appmenu libindicator7 indicator-application indicator-datetime indicator-messages libnux-2.0-0 nux-tools libunity-misc4 unity-2d-common
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get install unity unity-2d unity-2d-panel unity-2d-spread unity-asset-pool unity-services unity-lens-files unity-lens-music unity-lens-applications gir1.2-unity-5.0 unity-common indicator-sound indicator-power indicator-appmenu libindicator7 indicator-application indicator-datetime indicator-messages libnux-2.0-0 nux-tools libunity-misc4 unity-2d-common
sudo apt-get upgrade
I was able to fix a similar issue in the past like this.
