I am trying to run Java applications (ElasticSearch and Cassandra) on Ubuntu (14.04) running on Power PC hardware using the OpenJDK. I ran into an error:
The stack size specified is too small, Specify at least 1664k
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
I have found that the x86_64 OpenJDK java requires at least 160k for stack size. So it appears the Power PC architecture requires a stack size ten times larger than x86_64.
Are there any other Java settings that are specific to Linux Java running on Power PC architecture?
karel
  • 122,292
  • 133
  • 301
  • 332
The way to change the stack size for running java on the command line is -Xss
In this case it is: java -Xss1664k JavaApplication
If you are using Java applications that have configuration files (such as Cassandra or ElasticSearch) the stack size is often specified in the JAVA_OPTS variable of the configuration file.
Edit /etc/cassandra/cassandra-env.sh
Change JVM_OPTS="$JVM_OPTS -Xss 1664k" to JVM_OPTS="$JVM_OPTS -Xss1792k"
Try to start cassandra again. It will work.
Reference
Make sure you are running the ppc64el architecture other than powerpc. Powerpc is the 32 bits release, and and it is not recommend to run on POWER8 server.
On the other side, please use ppc64el, which is the 64-bits release and should have the stack size properly sized.
