My friend installed Ubuntu along side windows xp so I could dual boot, after a while I decided to delete the Ubuntu partition unaware that you need the xp recovery disk or something like that to fix windows. So every time I start my computer the grub rescue prompt appearers so is there a way for booting window from grub rescue without the window xp recovery disk?
Asked
Active
Viewed 457 times
When you open your computer there will be a logo of your motherboard manufacturer for example "Asus". When you see that then spam the ESC key. When the logo disapeers then you will see like a BIOS interface menu. Select "Boot Menu". There you should see your CD drive, for mine it is CD-DRIVE. BEFORE YOU SELECT THAT insert your CD, when you insert it they press enter on CD-DRIVE. Then it should boot into the disc. –
anonymous
- 1
- 1
