I have a script that's supposed to record a shoutcast stream for an hour, convert it to mp3, and then save it. The script runs correctly when I run it from the terminal, but I can't seem to get it to run in cron (where it should run every hour at the top of the hour).
Here's the line in crontab:
0 * * * * /medialib/tech/bin/recordstream 2>&1 >> /medialib/tech/cron.log
and here's the script:
#!/bin/bash
name="$(date +%s)"
mp3_name=$name.mp3
wav_name=$name.wav
timeout -sHUP 60m vlc -I dummy --sout "#transcode{channels=2}:std{access=file,mux=wav,dst=/medialib/stream_backup/wav/$wav_name" /medialib/tech/lib/listen.m3u
lame --mp3input /medialib/stream_backup/wav/$wav_name /medialib/stream_backup/$mp3_name
rm /medialib/stream_backup/wav/$wav_name
Thank you!
EDIT: Contents of cron.log (This text has been in the log file since it was transferred from an old server where it was working).
VLC media player 2.0.8 Twoflower
Command Line Interface initialized. Type `help' for help.
> Shutting down.
> Shutting down.
Firstly try to see if cron is running
ps -ef | grep cron
If it is not running, start it as root
sudo /etc/init.d/cron start (Ubuntu and Red Hat).
Secondly, check the permissions of the script, if it have the "x" option and then try to run
crontab -e
Try to see if the cron you made is listed with this command
crontab -l
EDIT:
Try to add /bin/bash right before your script call :
0 * * * * /bin/bash /script/file
Any more clues to solve it here.
