12
I installed nodejs with apt-get on 14.04
When I do nodejs -v
v0.10.25
and when i do node -v
node : command not found.
So I want to alias of nodejs to node
I inserted a line in ~/.bashrc
alias node=nodejs
Now I can access nodejs with node in a terminal.
But in my project, i use grunt which fires nodemon via gruntfile.js. Now nodemon tries to run node instead of nodejs
So again I get the same problem node : command not found.
So the alias doesn't work for non-interactive non-login shells.
Where should I make the alias for this specific purpose and get my problem solved?
Zanna
  • 72,312
Recently fixed this using nodejs-legacy.
Run the following command:
sudo apt-get install nodejs-legacy
This should fix it.
11
Well curiously, I have a node. It's an alternatives system symlink and I'm not quite sure how I got it (in a way that you don't). It was a while since I installed it so perhaps I followed this SO post or one like it... Who knows!
You could just write a little bash alias but that'll only work for one user at a time. It might just make more sense to add it as as symlink globally. I'm not sure there's any value going through the alternatives system so we can just plonk one in /usr/local/bin (this is where non-package-managed binaries should go):
sudo ln -s /usr/local/bin/nodejs /usr/bin/node
Edit: That SO post I talked about actually links back to one of ours which might be relevant. It suggests installing nodejs-legacy is the way forward.
Oli
  • 299,380
Since the bin directory is already in the PATH, you can simply create a symlink called node in the ~/bin directory linking to the actual binary.
 ln -s /usr/bin/nodejs ~/bin/node
