Have a new ponder hoping someone can answer. Keep in mind I am very new at linux and Ubuntu 14.04. What I would like to setup is setting certain programs to load at login to my account. I have not found a startup folder or setup options for programs to load at startup. Any Ideas?
Please remember I am very new to linux and Ubuntu desktop. I am still learning my way around and the code for terminal sessions. So please be very descriptive in responses. Thank you...
As you you say you're very new to Unix alike, so I'd give you a simple hint using GUI press Superkey or go directly to Dash on Launcher and type: Startup Applications launch the appropriate icon. When it's opened looks like this:
click Add then Browse and choose the path in a line command to an app you'd like to startup, by default they go to /usr/bin/ for example for psensor it be /usr/bin/psensor choose and press Add you can also name it your way.
JoKeR
  • 7,062
I found the startup applications applet in the computer and programs search button in the toolbar. I was able to setup the programs I wanted to startup at login. I am using a laptop that does not have a superkey, so this was the only way I could get to it. Ubuntu 14.04 desktop looks different than the image JohnnyEnglish has posted however his post helped me get to where I needed to. Thanks for the help, bud.
