I'm tring to install jdk 8 for weeks, but it fails.Following are some outputs,
sudo update-alternatives --config java
There is only one alternative in link group java (providing /usr/bin/java): /opt/java-oracle/jdk1.8.0/bin/java
Nothing to configure.
which java
   /usr/bin/java
java
 bash: /usr/local/java/jdk1.7.0_51/bin/java: No such file or directory
ls -l /usr/bin/java
 /usr/bin/java -> /etc/alternatives/java
ls -l /etc/alternatives/java
/etc/alternatives/java -> /opt/java-oracle/jdk1.8.0/bin/java
sudo update-alternatives --config javac
/opt/java-oracle/jdk1.8.0/bin/javac 1 manual mode
javac
  Error: could not find libjava.so
  Error: Could not find Java SE Runtime Environment.
If you can please give me a help to slove this problem. Thank You
I installed the jdk just fine. Here's what I did.
  1. Get the .rpm file from Oracle's website.
  2. Open up a terminal and type this command:sudo apt-get install alien
  3. Wait for alien to install.
  4. Type: sudo alien -i -c <path to the file>
  5. Wait for that to finish installing. It will look like it's not doing anything for a while, but it is.
  6. Test the installation with: java -version
  7. You're done!
I followed the suggested steps today, but was upset by the result. Mostly because installed Java was not registered in java-alternatives among other versions, and also because of apt complaining about "1 not fully installed or removed."
So I decided to provide an alternative answer.
The following steps made me happy today:
  1. Get the .tar.gz file from Oracle's website
  2. Use the following command to install the package converter specific to Java: sudo apt install java-package
  3. In the directory containing previously downloaded file, run the command: make-jpkg jdk-8u221-linux-x64.tar.gz (adjust the version if needed).
  4. Then run: sudo dpkg -i oracle-java8-jdk_8u221_amd64.deb (adjust the version if needed).
  5. If you have any other versions of Java installed, you may need to update alternatives: sudo update-java-alternatives --set oracle-java8-jdk-amd64
  6. Check everything is OK: java -version.
Now you can delete both .tar.gz and .deb files.
Yoory N.
  • 101
