I ran dolphin like this:
dolphin . &
I see messages in the console like these:
QPixmap::scaled: Pixmap is a null pixmap
How can I keep the console clean or silent?
Braiam
  • 69,112
epsilon8
  • 121
You can redirect the output to a file or to nowhere.
Using output redirection > you can redirect stdout and/or stderr away from the terminal.
To redirect stdout and stderr to a file use &> log.txt.
If you just want output to go way use &> /dev/null.
So you new command would be dolphin . &> /dev/null &
&> redirects all output
use > or 1> to redirect stdout only
use 2> to redirect stderr only
Note: if you want to append to a file rather than overwrite it use >> in place of >.
Dan
  • 6,784
Redirect all the output into a black hole:
dolphin . > /dev/null 2>&1 &
The 2, 1 and 0 (not used here) stand for STDERR (where all the error messages are sent), STDOUT (where normal output goes) and STDIN (where the input) comes from. In a normal terminal STDOUT and STDERR are both printed to screen.
The above example redirects STDOUT with > to /dev/null and then redirects STDERR into STDOUT so both output streams end up at /dev/null.
Oli
  • 299,380
