I have four printers if I go to dash and then printers. However, if when I print in the dialog there are many printers (100?) that show up that I have never seen/installed. I'm guessing they're network printers. How can I remove them or prevent them from showing up?
This problem only started happening on 14.04.
my file /etc/cups/cupsd.conf is below
# Sample configuration file for the CUPS scheduler.  See "man cupsd.conf" for a
# complete description of this file.
# Log general information in error_log - change "warn" to "debug"
# for troubleshooting...
LogLevel warn
# Deactivate CUPS' internal logrotating, as we provide a better one, especially
# LogLevel debug2 gets usable now
MaxLogSize 0
# Administrator user group...
SystemGroup lpadmin
# Only listen for connections from the local machine.
Listen localhost:631
Listen /var/run/cups/cups.sock
# Show shared printers on the local network.
Browsing Off
BrowseOrder allow,deny
BrowseAllow all
BrowseLocalProtocols CUPS dnssd
BrowseAddress @LOCAL
# Default authentication type, when authentication is required...
DefaultAuthType Basic
# Web interface setting...
WebInterface Yes
# Restrict access to the server...
<Location />
  Order allow,deny
</Location>
# Restrict access to the admin pages...
<Location /admin>
  Order allow,deny
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
  AuthType Default
  Require user @SYSTEM
  Order allow,deny
</Location>
# Set the default printer/job policies...
<Policy default>
  # Job/subscription privacy...
  JobPrivateAccess default
  JobPrivateValues default
  SubscriptionPrivateAccess default
  SubscriptionPrivateValues default
  # Job-related operations must be done by the owner or an administrator...
  <Limit Create-Job Print-Job Print-URI Validate-Job>
    Order deny,allow
  </Limit>
  <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>
    Require user @OWNER @SYSTEM
    Order deny,allow
  </Limit>
  # All administration operations require an administrator to authenticate...
  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default CUPS-Get-Devices>
    AuthType Default
    Order deny,allow
  </Limit>
  # All printer operations require a printer operator to authenticate...
  <Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>
    AuthType Default
    Order deny,allow
  </Limit>
  # Only the owner or an administrator can cancel or authenticate a job...
  <Limit Cancel-Job CUPS-Authenticate-Job>
    Order deny,allow
  </Limit>
  <Limit All>
    Order deny,allow
  </Limit>
</Policy>
# Set the authenticated printer/job policies...
<Policy authenticated>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit All>
    Order deny,allow
  </Limit>
</Policy>
Xu Wang
  • 357
  1. Open Firefox or any browser on: http://localhost:631/
  2. Administrations tab → Under Server title, Edit Configuration File
  3. Look for Browsing/BrowseLocalProtocols and set them to:
    Browsing Off
    BrowseLocalProtocols none
    then Save Changes
  4. Enter your username/password, done
If you prefer command line:
sudo nano /etc/cups/cupsd.conf
user.dz
  • 49,176
I thinnk best solution is to disable cups-browsed (this avoid autodetection but not the use of other remote printers):
sudo gedit /etc/cups/cups-browsed.conf
and change the line of BrowseRemoteProtocols to:
BrowseRemoteProtocols none
then restart system (or run sudo service cups-browsed restart).
arauzo
  • 1,098
