I was trying to activate network sharing on my computer and I had this error message from the terminal
Your wireless card or driver does not support Access Point mode.
My wireless card info is as follows
description: Wireless interface
   product: Centrino Advanced-N 6200
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:03:00.0
   logical name: wlan0
   version: 35
   serial: 00:27:10:80:db:30
   width: 64 bits
   clock: 33MHz
   capabilities: bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=iwlwifi driverversion=3.13.0-29-generic firmware=9.221.4.1 build 25532 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn"
I am not a comp guru but can follow instructions very well, please help.
Virusboy
  • 1,566
Answered very nicely here already,
To use your network card as wifi hotspot, it must support AP mode & master mode.
To check master-mode run:
sudo iwconfig wlan0 mode master.
If you dont get a error then it supports master-mode
To check AP run following command:
sudo apt-get install iw
Then run:
iw list
If there is 'AP' in the list of "Supported interface modes" your device will support the Access Point mode with hostapd.
But as you explained above, that it doesn't support AP mode, The wifi hotspot wont work as explained in the blog.
Unlike windows, linux-kernel doesn't provide same features for every wireless cards.So for a particular wifi-card, windows driver may support AP , but linux-driver may not.
One option is to purchase a wireless card which supports AP modes.
