On Ubuntu 10.04 I recently installed Python 2.7.1 (ActivePython from ActiveState). I use meld to diff code and had no issues with Python 2.6.5, but after moving to 2.7.1 I get the following error when I execute meld:
Meld requires pygtk 2.8.0 or higher
Looking in Synaptic Package Manager, I have python-gtk2 installed which I believe maps to pygtk, but since meld cannot find it, does that mean it is installed for 2.6.5?
If I run the following:
pip install pygtk
I get:
ImportError: No module named dsextras
dsextras seems to be part of PyGObject but if I try to do:
pip install pygobject
I get an error that indicates that this type of installation is only supported on Windows:
Not supported, ok [y/N]? Error: distutils build only supported on windows
What's the recommended way of migrating to a newer Python version? Is it possible to import the packages from 2.6.5 into 2.7.1 or do I risk running into compatibility issues?
Jorge Castro
  • 73,717
Fredrik H
  • 133
This is a better way of installing Python 2.7 into Ubuntu 10.04. What's the best way to get Python 2.5 and 2.7
brousch
  • 2,630
You'll run into compatibility issues with packages with binary modules, including pygtk.
As far as I understand, the ActiveState distribution is okay on windows where there's no native python, but external binary packages look less attractive on ubuntu. Your other options are upgrading to ubuntu 10.10, which I'd recommend, compiling your own python for your home, staying python2.6 compatible, or backporting the python2.7 package from 10.10.
Tobu
  • 473
