I've just attempted to run sudo apt-get dist-upgrade on my Ubuntu box, but am getting the following error... WARNING: The following packages cannot be authenticated! librdbmspp php5-ioncube-loader sw-libboost-date-time1.49.0 sw-libboost-system1.49.0 sw-libboost-filesystem1.49.0 sw-libboost-program-options1.49.0 sw-libboost-regex1.49.0 sw-libboost-serialization1.49.0 sw-libpoco
I've tried running... $ sudo apt-key update $ sudo apt-get update ... as found in this question, but I'm still getting the error.
Can anyone help, please?
Update on 5th June
Repos currently in /etc/apt/sources.list:
deb http://gb.archive.ubuntu.com/ubuntu/ precise main restricted universe multiverse
deb http://gb.archive.ubuntu.com/ubuntu/ precise-updates main restricted universe multiverse
deb http://gb.archive.ubuntu.com/ubuntu precise-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu precise partner
deb-src http://archive.canonical.com/ubuntu precise partner
deb http://security.ubuntu.com/ubuntu precise-security main restricted universe multiverse
deb-src http://security.ubuntu.com/ubuntu precise-security main restricted universe multiverse
deb http://autoinstall.plesk.com/ubuntu/PSA_11.5.30 precise all
deb http://autoinstall.plesk.com/debian/SITEBUILDER_11.5.10 all all
deb http://autoinstall.plesk.com/debian/BILLING_11.5.30 all all
apt-get:
Reading package lists...
Building dependency tree...
Reading state information...
The following NEW packages will be installed:
  linux-headers-3.2.0-63 linux-headers-3.2.0-63-generic
  linux-image-3.2.0-63-generic
The following packages will be upgraded:
  iproute libgnutls-dev libgnutls-openssl27 libgnutls26 libgnutls26:i386
  libgnutlsxx27 librdbmspp libssl-dev libssl-doc libssl1.0.0 libssl1.0.0:i386
  linux-generic linux-headers-generic linux-image-generic openssl
  php5-ioncube-loader sw-libboost-date-time1.49.0 sw-libboost-filesystem1.49.0
  sw-libboost-serialization1.49.0 sw-libboost-system1.49.0 sw-libpoco
23 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 63.2 MB of archives.
After this operation, 217 MB of additional disk space will be used.
Do you want to continue [Y/n]? WARNING: The following packages cannot be authenticated!
Install these packages without verification [y/N]?
apt-cache policy librdbmspp:
# apt-cache policy librdbmspp
librdbmspp:
  Installed: 2.0-735641.13060715
  Candidate: 2.0-735641.13073116
  Version table:
     2.0-735641.13073116 0
        500 http://autoinstall.plesk.com/ubuntu/PSA_11.5.30/ precise/all amd64 Packages
 *** 2.0-735641.13060715 0
        100 /var/lib/dpkg/status
TobyG
  • 111
librdbmspp:
  Version table:
The output shows that package comes from Plesk. I would bet the rest of the ones that are unauthenticated do too. So I wouldn't worry about it, it is Plesk's problem, just say "y" to "Install these packages without verification [y/N]?" and it will do the upgrade.
bain
  • 12,200
http://forum.parallels.com/showthread.php?297194-Cant-update-11-5-30-on-Ubuntu-bind9-fail! shows that this issue can be caused by AppArmor not being disabled.
From http://kb.parallels.com/112903:
Symptoms
AppArmor is a security tool that uses name-based mandatory access controls to restrict or confine the system access of “at risk” applications. AppArmor is not supported by Parallels Plesk Panel. Sometimes AppArmor can interfere with Plesk installation or functionality.
Resolution
Disable AppArmor using the following commands:
/etc/init.d/apparmor stop
/etc/init.d/apparmor teardown
update-rc.d -f apparmor remove
NGRhodes
  • 9,680
