I turned on my pc this morning and unity will not load at all. I have tried loading it manually using ctrl+alt+f1 and all i got from it was the following:-
compiz (core) - Info: Loading plugin: core
compiz (core) - Info: Starting plugin: core
compiz (core) - Info: Loading plugin: ccp
compiz (core) - Info: Starting plugin: ccp
compizconfig - Info: Backend     : gsettings
compizconfig - Info: Integration : true
compizconfig - Info: Profile     : unity
compiz (core) - Info: Loading plugin: composite
compiz (core) - Info: Starting plugin: composite
compiz (core) - Info: Loading plugin: opengl
compiz (core) - Info: Starting plugin: opengl
libGL error: dlopen /usr/lib/x86_64-linux-gnu/dri/r600_dri.so failed (/usr/lib/x86_64-
linux-gnu/dri/r600_dri.so: undefined symbol: _glapi_tls_Dispatch)
libGL error: dlopen ${ORIGIN}/dri/r600_dri.so failed (${ORIGIN}/dri/r600_dri.so: cannot open shared object file: No such file or directory)
libGL error: dlopen /usr/lib/dri/r600_dri.so failed (/usr/lib/dri/r600_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: dlopen /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so failed (/usr/lib/x86_64-linux-gnu/dri/swrast_dri.so: undefined symbol: _glapi_tls_Dispatch)
libGL error: dlopen ${ORIGIN}/dri/swrast_dri.so failed (${ORIGIN}/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: dlopen /usr/lib/dri/swrast_dri.so failed (/usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
compiz (core) - Info: Loading plugin: compiztoolbox
compiz (core) - Info: Starting plugin: compiztoolbox
compiz (core) - Info: Loading plugin: decor
compiz (core) - Info: Starting plugin: decor
compiz (core) - Info: Loading plugin: copytex
compiz (core) - Info: Starting plugin: copytex
compiz (core) - Info: Loading plugin: snap
compiz (core) - Info: Starting plugin: snap
compiz (core) - Info: Loading plugin: resize
compiz (core) - Info: Starting plugin: resize
compiz (core) - Info: Loading plugin: gnomecompat
compiz (core) - Info: Starting plugin: gnomecompat
compiz (core) - Info: Loading plugin: move
compiz (core) - Info: Starting plugin: move
compiz (core) - Info: Loading plugin: place
compiz (core) - Info: Starting plugin: place
compiz (core) - Info: Loading plugin: mousepoll
compiz (core) - Info: Starting plugin: mousepoll
compiz (core) - Info: Loading plugin: regex
compiz (core) - Info: Starting plugin: regex
compiz (core) - Info: Loading plugin: imgpng
compiz (core) - Info: Starting plugin: imgpng
compiz (core) - Info: Loading plugin: vpswitch
compiz (core) - Info: Starting plugin: vpswitch
compiz (core) - Info: Loading plugin: grid
compiz (core) - Info: Starting plugin: grid
compiz (core) - Info: Loading plugin: animation
compiz (core) - Info: Starting plugin: animation
compiz (core) - Info: Loading plugin: expo
compiz (core) - Info: Starting plugin: expo
compiz (core) - Info: Loading plugin: session
compiz (core) - Info: Starting plugin: session
compiz (core) - Info: Loading plugin: wall
compiz (core) - Info: Starting plugin: wall
compiz (core) - Info: Loading plugin: fade
compiz (core) - Info: Starting plugin: fade
compiz (core) - Info: Loading plugin: unitymtgrabhandles
compiz (core) - Info: Starting plugin: unitymtgrabhandles
compiz (core) - Info: Loading plugin: ezoom
compiz (core) - Info: Starting plugin: ezoom
compiz (core) - Info: Loading plugin: workarounds
compiz (core) - Info: Starting plugin: workarounds
compiz (core) - Info: Loading plugin: scale
compiz (core) - Info: Starting plugin: scale
compiz (core) - Info: Loading plugin: unityshell
compiz (core) - Info: Starting plugin: unityshell
WARN  2014-06-03 10:55:31 unity.glib.dbus.server GLibDBusServer.cpp:586 Can't register object 'com.canonical.Autopilot.Introspection' yet as we don't have a connection, waiting for it...
WARN  2014-06-03 10:55:31 unity.glib.dbus.server GLibDBusServer.cpp:586 Can't register object 'com.canonical.Unity.Debug.Logging' yet as we don't have a connection, waiting for it...
compiz (unityshell) - Error: GL_ARB_vertex_buffer_object not supported
compiz (core) - Error: Plugin initScreen failed: unityshell
compiz (core) - Error: Failed to start plugin: unityshell
compiz (core) - Info: Unloading plugin: unityshell
X Error of failed request:  BadWindow (invalid Window parameter)
  Major opcode of failed request:  18 (X_ChangeProperty)
  Resource id in failed request:  0x4000006
  Serial number of failed request:  9909
  Current serial number in output stream:  9913
It was all working fine yesterday but this morning there was nothing.
Parto
  • 15,647
Jarmand83
  • 13
It seems a bug that affects many users, me too (13.10). I solved with this:
Unity not Working 14.04
user288431
  • 16
