I have downloaded the tar.gz package from the site and then I have extracted using tar -zxvf command as mentioned over there. After that I used sudo apt-get install build-essential then I further installed libssl-dev. Then I changed directory to the aircrack folder. But when I type either sudo make or just make I am getting this same error. I don't know what to do. I have installed the file what they have asked in the error as well. Still the same error is shown. Okay I am not permitted to upload images.
The error is :
common.mak:85: *** Cannot find development files for any supported version of libnl. install either libnl1 or libnl3..  Stop.
2707974
  • 10,758
Pikpaul1991
How to install without compiling
Execute this command in your Terminal:
sudo apt-get update
sudo apt-get install aircrack-ng
Naveen
  • 9,551
If you want to install it from source (though Naveens's answer would be easier) you must install libnl-dev.
To install from source you need to install the -dev packages for every library that the program you are compiling uses. Whenever a program you are compiling asks for a library look it up in synaptic (if you don't have it run apt-get install synaptic as root) then select the library's -dev package, which contains the headers that the program needs to compile to the library.
john
  • 139
