When ubuntu loads up, it asks to log in.
When I press my username or "other", login window flicks a bit and is right back where it was, nothing happens. Can't log in.
Any ideas what's wrong?
xsession-error:
(gnome-terminal:3401): Gtk-WARNING **: Failed to load type module: (null) `menu_proxy_module_load': gnome-terminal: undefined symbol: menu_proxy_modu le_load
Jorge Castro
  • 73,717
It sounds like the upgrade didn't finish.
To complete the upgrade, boot up, and then at the login screen you'll need to drop to a ttyy (a terminal).
To do that, use the keyboard shortcut Ctrl-Alt-F1.
Login with your username and password, then run the following:
sudo dpkg --configure -a
Let that finish, and then you can reboot by running sudo reboot.
Your system should be back to normal.
jrg
  • 61,707
