Lubuntu 14.04 was working really great. . .until I messed up and had to do a complete fresh reinstall.
Now I receive error messages when I input commands into the Terminal, even after immediately completing the fresh install.
For example I type:
sudo leafpad ‬/etc/default/
or sudo leafpad ‬/etc/default/grub
I get:
sudo: leafpad: command not found
I type:
sudo update-initramfs ‬-u
or sudo update-grub
I get:
sudo: update-initramfs: command not found
or sudo: update-grub: command not found
If I use the command mkdir I get:
mkdir: command not found
I also get this same exact error message, command not found, with sudo apt-get and wget
In other words I can't do anything that I was able to do when inputting commands into the terminal.
So I cannot add any repositories or update anything at all. I am not really sure what is causing the problem(s).
It appeared to me that Lubuntu installed and booted up OK. However just as soon as I enter anything into the Terminal I immediately get the above error messages. I have tried to do the reinstall three times, same error messages.
If anyone can suggest any fixes I would really appreciate it very much. Thank you!
TuKsn
  • 4,440
