I have some questions about some Terminal commands:
  1. Why must you do sudo apt-get update before installing an program or after downloading something? Does it update Ubuntu then?
  2. What is the different between sudo gedit /location/to/afile.txt and gksu gedit /location/to/afile.txt?
  3. Why people don't use -y on the end of a command, like for example in sudo apt-get install programx -y.
  4. What does the -i and -l (are there any more) mean in a Terminal?
  5. How can I unpack any .zip or .tar.gz file in a Terminal?
oerdnj
  • 7,940
Korkel
  • 1,168
sudo apt-get update updates the repository information of apt, so you can install the latest version of packages.
sudo gedit will ask you for a password in the terminal window, while gksu gedit prompts for a password with a GUI.
Most people like to review any changes they make with root permissions, that's why they refrain from using sudo apt-get -y and similar.
As for -i and -l, these look like parameters you would give to a command. Each command behaves differently and uses different switches, so without knowing the specific command, it's not possible to tell what these mean. Read the manual (man apt-get, for example) or try using --help with any command.
Use unzip file.zip to extract a zip file and tar xzf file.tar.gz to extract a tar.gz file.
kraxor
  • 5,627
No , it won't update Ubuntu. It just update the repositories and PPA's.
Don't open gui application as root through sudo instead of sudo, you have to use gksu. gksu package is not installed by default, so run this command sudo apt-get install gksu to install gksu package.
Why don't people not use -y on the end of a command, like sudo apt-get programx -y?
Because people want apt-get to always propmt(ask for permission) before installing packages.
How can I unpack any .zip or .tar.gz file by Terminal?
  • unzip filename.zip
  • tar -xzvf file.tar.gz
Avinash Raj
  • 80,446
