I have an old PC with AMD Sempron 3000+ and a half GB of ram. I also have an old laptop with Intel Core 2 Duo and 1GB of ram. If I am not wrong they are 64 bits version of processors.
I try to run live CD of Lubuntu 14.04 amd64 version and both: success. but when install it, both: failed. I used USB flash disk to run live cd.
Is there any explanations of these? Btw, I usually use 32 bits version. Thanks..
Wastono
Normally, Intel does show what processors have what technical Specs on Processor chips. This is what you should look at.
I did not see an Intel Chip that wasn't 64 bit. However your Sempron is a 32 bit and will not accept a 64 bit install.
As a rule of thumb, anything under 4 GB of RAM should have a 32 bit OS installed.
Virusboy
  • 1,566
