I want to install a phpBB forum on my local host, but for that I need get something like IIS or XAMPP, PHP and SQL on my Ubuntu.
Can someone tell me how to do that?
Can I also get a tutorial how to CHMOD spefic files/maps?
Korkel
  • 1,168
The following will show you how to setup LAMP, and install phpBB on Ubuntu 14.04 - Desktop X86-64 for the purpose of running it locally through http#://localhost/. If your goals are more advanced than that you will need to provide further clarifications in your post.
[Any urls I've typed that have a # after the http/https should not be typed. I just did that to bypass the max 2 urls limit, and the inability to post local host links.]
Steps:
  1. In terminal type "sudo apt-get install lamp-server^".
  2. You will be prompted to pick a root password for MySQL.
  3. In terminal type "sudo apt-get install phpmyadmin".
  4. You will be prompted to pick a web server; choose "apache2".
  5. You will be prompted to configure database for phpmyadmin wiht dbconfig-common; choose "yes".
  6. You will be prompted to provide the password for the database's admin user. Enter the password you previously choose for MySQL root.
  7. You will be prompted to pick a password for phpmyadmin.
  8. Open Mozilla Firefox, go to https://www.phpbb.com/downloads/ and download the .zip file for phpBB. [At this time the current version is 3.0.12.]
  9. Navigate to where you saved it, the default is your Downloads folder, and extract the contents by right clicking and choosing "extract here".
  10. Enter the folder that was extracted, select all, and copy.
  11. In terminal type "sudo -i nautilus",browse to "/var/www/html", delete "index.html", and paste in the PhpBB files.
  12. Right click on "config.php" and change the "others" settings to "read and write".
  13. Open Firefox, and visit "http#://localhost/install/index.php". Click the "install" tab, "proceed to next step", and "start install".
  14. In another tab visit "http#://localhost/phpmyadmin/". Login using "root" as the username, and the MySQL password you choose during installation.
  15. Click on the "databases" tab, enter a name (eg: phpbb), and click "create". Under the tab "more" click "prividges", and the "add user". Enter a username, enter a password, and click "check all" for global permissions. Leave the other fields blank, and click "go" at the very bottom of the page. Logout of phpmyadmin.
  16. In the first tab you can now enter you details. Being the name you choose for the database, the user name you just created, and the password for the user account you just created.
  17. You will now setup a user account on PhpBB.
    screenshot 1: https#://copy.com/NRb3H93J4G1U
  18. Now the "advanced settings" for which you can leave the default settings.
  19. You will get a congratulations screen telling you that phpBB is setup.
  20. In terminal type "sudo -i nautilus", and navigate to "/var/www/html". Delete the "install" directory.
  21. You can now access phpBB from "http#://localhost/".
    screenshot2 = https#://copy.com/pqbNg62StakT
    screenshot3 = https#://copy.com/YlfAlkPRR6P6
Notes:
yarwest
  • 105
mango
  • 41
try this. Install apache2 web server, php5, mysql DBMS and phpmyadmin like this
  sudo apt-get install apache2 php5 mysql-client-5.5 mysql-server-5.5 phpmyadmin
and you should have the core server software installed in your system. To deploy web pages, put them into the www folder found like this.
 cd /var/www/ && ls #will display your contents in the browser.
Now you might try to start the server and get something like
Could not reliably determine the server Path
No worries. Just add this line below to your apache2.conf file located in the /etc directory. To open this file type this command in your terminal.
 sudo nano /etc/apache/apache2.conf
 #paste this line below somewhere in the middle of that opened file
 ServerName 127.0.0.1
Then restart your server like this
 sudo service apache2 restart
Now you can open your browser and type in localhost better yet localhost/phpmyadmin
Remember, To deploy your web files, just dump them in the www folder described above. Ofcourse i skipped the password stuff while the dpkg installs mysql and dependacies.
Zuko
  • 1,277
