I wanted to install teamviewer on linux 64-bit system.
What I did was to download teamviewer.deb file and install it as below:
sudo dpkg -i install teamviewer.deb
Then I wanted to correct dependency problem so I issued the following command:
sudo apt-get install libc6:i386 libgcc1:i386 libasound2:i386 libfreetype6:i386 zlib1g:i386 libsm6:i386 libxdamage1:i386 libxext6:i386 libxfixes3:i386 libxrender1:i386 libxtst6:i386
I got the following error:
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
I then tried:
sudo apt-get install -f
Again I got the following error:
Even I tried to install gdebi, but I got the above error again.
I emptied archives folder:
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
Again I have problem installing my deb package. Is there anything I could do now to solve this problem?
I've read the below article as well:
Installed Teamviewer using a 64-bits system, but I get a dependency error
EDIT:
I found libperl5.14:amd64 as a broken package. I used:
sudo apt-get remove libperl5.14:amd64
I got the following message:
E: Unable to locate package Broken
This is my whole apt.log file. I found a few more broken packages. I've done the same thing and got the same message.
EDIT 2:
I tried to install teamviewer_linux.deb via software center and I found repair button I clicked it and again I got the error below:
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
even after package removal and installing it via software center I got the error below:
Can not install 'libfreetype6:i386'
EDIT 3:
Can sources.list affect the process of installing deb packages? This is the only thing I'm suspicious of!
EDIT 4:
When after that I type sudo apt-get install -f I get this message:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded
EDIT 5:
Output of sudo dpkg -i teamviewer_linux.deb:
dpkg: error processing package teamviewer (--install):
dependency problems - leaving unconfigured
teamviewer
