I have Toshiba Satellite C850-B798 with Windows 7 x64 installed.
I downloaded Ubuntu desktop x64 ISO and burn it to flash memory by universal installer, when I choose to boot from flash it give me nothing only black screen, I enter to BIOS to disable secure boot but I didn't find this option, also I didn't find UEFI or CSM.
I updated the BIOS to the last version 6.80 but nothing new happened, and I installed Ubuntu x86 but also the same results.
I installed win 8.1 x64 and I tried to find UEFI but I didn't find it.
I tried the ISO on vmware and it works well, also flash memory works well.
Simply, I tried all mentioned solutions but I still can't install Ubuntu, Why?
I also tried unetbootin, same results. There is no problem with boot order, and I installed win 8.1 by the same flash and same boot order and it worked fine
Seth
  • 59,332
Try and create the bootable USB with this http://unetbootin.sourceforge.net. I had the same issue, mine worked with this.
You may need to enter your BIOS and look at your system boot order. I suspect that booting from a bootable CD/DVD disk is not enabled or is ordered wrong (i.e. listed after curretnly installed operating system). A USB may also work as it could have a different boot priority in the BIOS from a CD/DVD
Finally, Ubuntu installed on my laptop, I used unetbootin but with the option of install iso on the C partition and then it restarted and give me console to choose if I want boot in win 8 or in unetbootin. thanks every body, but I hop to fix this issue cause booting with unetbootin is not efficient cause when partitioning I can't delete the C partition cause the iso installed on it and I will be obliged to use dual operating system .
