I've recently had a Windows 7 malfunction and decided to give Ubuntu a try. I noticed that 14.04 had been released and decided to grab it. It's been working fine up until yesterday. For some reason, it's having difficulty downloading anything or updating or upgrading when I put in "sudo apt-get update" or "sudo apt-get upgrade".
The error I'm coming across is:
dpkg: error processing package linux-image-3.13.0-27-generic (--remove):
 subprocess installed post-removal script returned error exit status 1
 linux-image-extra-3.13.0-27-generic
This is only a piece of the code, but it's been identified as a bug, but I'm not sure how to fix it or how to amend it.
I'm not having problems functionality wise, it's just annoying to not be able to update or download anything.
Braiam
  • 69,112
tango
$ cat /etc/default/grub
grub# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
grub.cfg is malformed. "grub#" should just be "#". Edit the file with sudo gedit /etc/default/grub and remove the first 4 characters. After you have done that run sudo update-grub and then sudo apt-get -f install
W: Duplicate sources.list entry http://archive.canonical.com/ubuntu/ trusty/partner amd64 Packages (/var/lib/apt/lists/archive.canonical.com_ubuntu_dists_trusty_partner_binary-amd64_Packages)
W: Duplicate sources.list entry http://archive.canonical.com/ubuntu/ trusty/partner i386 Packages (/var/lib/apt/lists/archive.canonical.com_ubuntu_dists_trusty_partner_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
grep -rH partner /etc/apt/sources* shows that you have the partner repository enabled in /etc/apt/sources.list and /etc/apt/sources.list.d/canonical_partner.list. It only needs to be enabled once so to fix it do sudo rm -f /etc/apt/sources.list.d/canonical_partner.list then sudo apt-get update.
bain
  • 12,200
