As the title suggests, i am stuck at the login screen. My system (ubuntu 14.04) was working fine and the problem appeared after i installed all updates and the following restart.
Basically i can log in, but unity won't load. I only see the standard wallpaper (not my personal) and i can use the mouse.
I tried several things...like
-install lightdm-gtk-greeter
-sudo apt-get install compizconfig-settings-manager
export DISPLAY=:0
ccsm
-unity --reset
-sudo dconf reset -f /org/compiz/ (shows always wrong command...)
-enabling the unity plugin (the plugin was already enabled,so...)
-rm -rf ~/.compiz-1 ~/.config/compiz-1
If i "startx" (via ALT-CTRL-F1) i get this output
Loading extension GLX
modprobe: FATAL: Module fglrx not found.
(WW) fglrx: No matching Device section for instance (BusID PCI:081:0:1) found
Loading extension FGLRXEXTENSION
[glesx] __glESXExtensionInit: No GL ES2.0 capable screen found!
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:           Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
>                    Ignoring extra symbols
Errors from xkbcomp are not fatal to X server
My System: Ubuntu 14.04 64bit I5-3570k ATI Radeon HD 7970 Ghz
Edit: With the old Kernel 3.13-0-24 it works...the newer 3.13.0-27 is the problem
