I have installed Ubuntu 12.04 LTS server .
How can i run more than .sh file in the same time (opening more than terminal)
I can use it on desktop version but i use server version.
Is it possible? if yes how can do?
Muath
  • 409
By default Ubuntu has 7 ttys, on Server they are all command line (desktop the 7th is for X use) You can switch between then using Ctrl + Alt + F1 to Ctrl + Alt + F7
This would allow you run your script in 7 different sessions.
You can also background processes by starting them as normal, but appending an & to the end e.g.
yourscript.sh &
If your script does not terminate itself you will need to locate the pid and kill it, for more detail on killing read:
NGRhodes
  • 9,680
Use screen. It's perfectly when you need multiple terminals. Specially when you are connected via ssh and you don't want to start another session.
You can, for example, run a command in it, detach, go to another machine, reattach and everything is still there.
Another similar application that provides the same is tmux.
chaos
  • 28,186
Linux will process one process at a shell at a time, which means script running in your scenario.
At a same time if you need to do some other tasks through shell .. you can use other consoles from tty 1 to tty6.
tty 7 is GUI [ currently using Desktop ].
Move to tty 1 from current desktop. press ctrl + Alt + F1 . After that use Alt + F2 to go to tty 2 and follow upto F3 F4 F5 F6 and F7 for GUI
