I have a 11.04 x86 server.
I ran sudo apt-get install vsftpd and that was successful. But I cannot find the vsftpd.conf file anywhere. I thought it was supposed to be in /etc/vsftpd.conf.
You've a weird issue, try clearing you cache, update your repository information and install it again:
sudo apt-get clean
sudo apt-get update
sudo apt-get install --reinstall vsftpd
If this did not work, purge vsftpd (remove it including its configuration files) and reinstall it:
sudo apt-get purge vsftpd
It sounds like the installation didn't complete successfully. The quickest solution is probably going to be to reinstall vsftpd:
Late to the party bu hope what I discovered is useful.
The file is not there after install. However
/etc/vstftd.conf
will be created after starting up the server.
It's installed with
and started with
sudo systemctl start vsftpd.service
This should do the job.
If you cannot find the vsftpd.conf under /etc/vstftd.conf, then you need to start vsftpd at least once.
This will create the config file afterwards
ls -lahG /etc
I had this problem too. When I observed the installation log carefully, it turned out that the installation was stopping before re-installing the directory "srv/ftp". I deleted the directory ftp from /srv so that /srv was empty. Then I reinstalled and had my original vsftpd.conf script replaced in /etc/vsftpd.conf.
try this command :
sudo find . -type f -name vsftpd.conf|grep vsftpd.conf
it should find the file in ./etc/
if the file is not there, then try following command :
and then the find again -
