I have a system that has optimus Nvidia card, so when i try to install wine it says.
The following packages will be REMOVED:
nvidia-libopencl1-331-updates
I have tried wine1.6 & wine1.7 same they will remove it nvidia-libopencl1-331-updates and i will not be able to use Optimus.
Is there any work around to install wine ?
one@Ubuntu:~$ sudo apt-get install wine1.7
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libavdevice53 libavfilter3 libswresample0 smplayer-translations
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
binfmt-support fonts-horai-umefont fonts-unfonts-core fonts-wqy-microhei gnome-exe-thumbnailer icoutils libasn1-8-heimdal:i386 libcapi20-3
libcapi20-3:i386 libdb5.3:i386 libexif12:i386 libgd3:i386 libgif4:i386 libglu1-mesa:i386 libgphoto2-6:i386 libgphoto2-port10:i386
libgpm2:i386 libgssapi3-heimdal:i386 libgstreamer-plugins-base0.10-0:i386 libgstreamer0.10-0:i386 libhcrypto4-heimdal:i386
libheimbase1-heimdal:i386 libheimntlm0-heimdal:i386 libhx509-5-heimdal:i386 libieee1284-3:i386 libkrb5-26-heimdal:i386 liblcms2-2:i386
libldap-2.4-2:i386 libltdl7:i386 libmpg123-0:i386 libncurses5:i386 libodbc1 libopenal1:i386 libosmesa6 libosmesa6:i386
libroken18-heimdal:i386 libsane:i386 libsasl2-2:i386 libsasl2-modules:i386 libsasl2-modules-db:i386 libusb-1.0-0:i386 libv4l-0:i386
libv4lconvert0:i386 libvpx1:i386 libwind0-heimdal:i386 libxpm4:i386 ocl-icd-libopencl1 ocl-icd-libopencl1:i386 odbcinst odbcinst1debian2
p11-kit-modules:i386 p7zip ttf-wqy-microhei unixodbc wine-gecko2.24 wine-gecko2.24:i386 wine-mono4.5.2 wine1.7-amd64 wine1.7-i386:i386
winetricks
Suggested packages:
libterm-readline-gnu-perl libterm-readline-perl-perl isdnutils-doc isdnutils-doc:i386 libgd-tools:i386 gphoto2:i386 gtkam:i386 gpm:i386
libvisual-0.4-plugins:i386 gstreamer-codec-install:i386 gnome-codec-install:i386 gstreamer0.10-tools:i386 gstreamer0.10-plugins-base:i386
liblcms2-utils:i386 libmyodbc odbc-postgresql tdsodbc unixodbc-bin libportaudio2:i386 libroar-compat2:i386 hplip:i386 hpoj:i386
libsane-extras:i386 libsasl2-modules-otp:i386 libsasl2-modules-ldap:i386 libsasl2-modules-sql:i386 libsasl2-modules-gssapi-mit:i386
libsasl2-modules-gssapi-heimdal:i386 opencl-icd:i386 p7zip-full dosbox:any winbind
Recommended packages:
wine1.5-amd64 wine1.5-i386:i386 unixodbc:i386 wine-mono4.5.2:i386 wine
The following NEW packages will be installed:
p11-kit-modules:i386 p7zip ttf-wqy-microhei unixodbc wine-gecko2.24 wine-gecko2.24:i386 wine-mono4.5.2 wine1.7 wine1.7-amd64
wine1.7-i386:i386 winetricks
0 upgraded, 61 newly installed, 1 to remove and 0 not upgraded.
Need to get 166 MB of archives.
After this operation, 537 MB of additional disk space will be used.
Do you want to continue? [Y/n]
aptitude suggested by @Yuriy Nazarenko
sudo aptitude install wine1.7
binfmt-support{a} fonts-horai-umefont{a} fonts-unfonts-core{a} fonts-wqy-microhei{a} gnome-exe-thumbnailer{a} icoutils{a}
libasn1-8-heimdal:i386{a} libcapi20-3{a} libcapi20-3:i386{a} libdb5.3:i386{a} libexif12:i386{a} libgd3:i386{a} libgif4:i386{a}
libglu1-mesa:i386{a} libgphoto2-6:i386{a} libgphoto2-port10:i386{a} libgpm2:i386{a} libgssapi3-heimdal:i386{a}
libgstreamer-plugins-base0.10-0:i386{a} libgstreamer0.10-0:i386{a} libhcrypto4-heimdal:i386{a} libheimbase1-heimdal:i386{a}
libheimntlm0-heimdal:i386{a} libhx509-5-heimdal:i386{a} libieee1284-3:i386{a} libkrb5-26-heimdal:i386{a} liblcms2-2:i386{a}
libldap-2.4-2:i386{a} libltdl7:i386{a} libmpg123-0:i386{a} libncurses5:i386{a} libodbc1{a} libopenal1:i386{a} libosmesa6{a}
libosmesa6:i386{a} libroken18-heimdal:i386{a} libsane:i386{a} libsasl2-2:i386{a} libsasl2-modules:i386{a} libsasl2-modules-db:i386{a}
libusb-1.0-0:i386{a} libv4l-0:i386{a} libv4lconvert0:i386{a} libvpx1:i386{a} libwind0-heimdal:i386{a} libxpm4:i386{a}
ocl-icd-libopencl1{ab} ocl-icd-libopencl1:i386{ab} odbcinst{a} odbcinst1debian2{a} p11-kit-modules:i386{a} p7zip{a} ttf-wqy-microhei{a}
unixodbc{a} wine-gecko2.24{a} wine-gecko2.24:i386{a} wine-mono4.5.2{a} wine1.7 wine1.7-amd64{a} wine1.7-i386:i386{a} winetricks{a}
0 packages upgraded, 61 newly installed, 0 to remove and 0 not upgraded.
Need to get 166 MB of archives. After unpacking 537 MB will be used.
nvidia-libopencl1-331-updates : Conflicts: libopencl1 which is a virtual package.
Conflicts: libopencl1:i386 which is a virtual package.
ocl-icd-libopencl1 : Conflicts: libopencl1 which is a virtual package.
ocl-icd-libopencl1:i386 : Conflicts: libopencl1 which is a virtual package.
The following actions will resolve these dependencies:
Remove the following packages:
1) nvidia-libopencl1-331-updates
Leave the following dependencies unresolved:
2) nvidia-331-updates recommends nvidia-libopencl1-331-updates
Accept this solution? [Y/n/q/?]
