I use bluefish a lot for coding etc but at the moment it is just closing. I have extracted the following from the logs. Does it mean anything to anyone?
 May 26 15:26:39 villa kernel: [  247.521915] bluefish[2262]: segfault at 198 ip 00007f9c2b4376e1 sp 00007fff7c233630 error 4 in libgtk-3.so.0.1000.8[7f9c2b2e1000+4ff000]
Braiam
  • 69,112
maxum
  • 155
The program is hitting a segmentation fault in libgtk-3.so which is possibly caused due to accessing a memory segment which the program does not have correct permissions or access to. Check if all the dependencies are updated and correct. Sometimes using a wrong version of the library could cause similar issues.
Next check the output of ulimit -c, if this is set to 0 then you won't get a core dump instead you will have to set ulimit -c unlimited in your ~/.profile.
Once you get the core file you could possibly submit the application crash report and the core file.
askb
  • 790
