30
Why do we use sudo to perform a terminal command as an administrative? Why isn't it admin or something else? Is there a reason for sudo?
muru
  • 207,228
Mohammad
  • 593
  • 17
8 Answers8
32
From Wikipedia:
sudo is a program for Unix-like computer operating systems that allows users to run programs with the security privileges of another user (normally the superuser, or root). Its name is a concatenation of "su" (substitute user) and "do", or take action.
Unlike the su command, users typically supply their own password to sudo rather than the root password. After authentication, and if the /usr/local/etc/sudoers (sometimes found at /etc/sudoers) configuration file permits the user access, then the system will invoke the requested command. The sudoers configuration file enables a huge amount of configurability, including but not limited to: enabling root commands only from the invoking terminal; not requiring a password for certain commands; requiring a password per user or group; requiring re-entry of a password every time or never requiring a password at all for a particular command line. It can also be configured to permit passing arguments or multiple commands, and even supports commands with regular expressions.
Its a temporary one-time command with superuser (administrator) privileges without direct root login.
Tim
  • 33,500
Virusboy
  • 1,566
23
xkcd: Sandwich
Before sudo, most administrators were logged-in as the root user because it is an easy way to configure your system, as you have all the rights. However, a small mistake, or a wrong internet link and your whole system could be affected or even compromised.
Due to this problem, sudo appeared. The aim was to use administrative privileges only for a short period of time, and only when required. In addition, this would avoid the user logging into another account. This would obviously enhance the system safety.
Under Ubuntu, they choose to enhance the safety of your system. Thus, they decided to follow the ‘sudo’ way. The root user is disabled; there is no need for it and especially no risk that a user logged-in via the X interface with the root user. In addition, they've allowed every command to be launched with sudo for authorized users. The cool thing is that power-users can access the root account.
Drawbacks of sudo :
  • Which commands to you allow via sudo
  • You need to write sudo before every command requiring administrative privilege
  • Every so often you need to re-type the password.
What does sudo mean? Its name is a concatenation of "su" (substitute user) and "do".
Why sudo not admin? I think sudo means admin for a specific time and only when you need it.
People who are coming from windows environment should understand why it is not admin :)
References : Site
Picture : xkcd
nux
  • 39,152
11
From Linux.com, a product of the Linux Foundation:
Sudo stands for either "substitute user do" or "super user do" (depending upon how you want to look at it). What sudo does is incredibly important and crucial to many Linux distributions. Effectively, sudo allows a user to run a program as another user (most often the root user).
[Emphasis mine.] Source
Cerran
  • 390
superuser do
There's a command, su, for becoming the superuser, so you might say
$ su
# apt-get install somehorror
# exit
sudo lets you do that in one swoop, and you don't have to remember to renounce your magic powers.
$ sudo apt-get install somehorror
Whether "superuser" is what su originally derived from, it is inaccurate since the username you give it doesn't have to be a superuser. Ditto for executing commands as another user using sudo -u.
"Substitute user" is more accurate, but sounds clunky. It makes me think of a substitute teacher.
Therefore I prefer to think of su as simply "switch user" and sudo thus as "switch user & do".
nux
  • 39,152
otus
  • 873
As others have commented, sudo's name is based on the "su" command (set userid) used to run a command as another user. "Su and do something". Sine the default for su was use ID zero (root/admin) and that was its most common use, the term "superuser" was created as a backronym.
Regarding why it is't "admin" or "set user" something like that -- Traditional Unix commands tend to be minimal abbreviations for historical reasons having to do with Unix's origins.
For the most basic reason we need to go back to the same reason it's called Unix in the first place. Much of Unix was inspired by one of the early multiuser multitasking operating systems, MIT's Multics. (Unix gets its name either as "the singular of Multics" or "castrated Multics", depending on who you ask and their mood at the moment.)
Among Multics' other innovations, it introduced the concept of separating the actual file location from the directory information, allowing a single file to have multiple names. ("Links", in Unix terms.) Multics took (overly) full advantage of this; most Multics commands have both ALongNameThatIsImpossibleToType and ASNTOECR (a short name that only experts can remember). Experience showed that the long names really didn't add much user-friendliness since, realistically, at that time all users were or quickly became "experts" and almost nobody ever used the long names. When Unix adopted some of Multics' design, one of their simplifications was to discard the unused long names and keep only the expert-friendly short names.
This also fit well with the Unix philosophy of reducing the operating system and its core command set to their essentials, permitting it to run efficiently on smaller systems. In those days programmers were still conserving every byte and cycle possible. Processors were tremendously slower, terminal speeds were likewise tremendously slower, and memory was tremendously more expensive (and slower, and had tiny caches if any). Keeping system commands down to a minimal length may not have actually saved much (if any) real resources, but it "felt right" for the mindset of the time.
If you really insist upon user-friendly command names, the Unix answer would be "You know how to write a shell script; implement it yourself. If you don't know how to write a shell script, you need to learn how to do so. If you don't like learning and/or coding, you're not going to be happy with Unix and should use something else."
keshlam
  • 31
From the Sudo website :
"What is Sudo?
Sudo (su "do") allows a system administrator to delegate authority to give certain users (or groups of users) the ability to run some (or all) commands as root or another user while providing an audit trail of the commands and their arguments."
"Sudo was first conceived and implemented by Bob Coggeshall and Cliff Spencer around 1980 at the Department of Computer Science at SUNY/Buffalo. It ran on a VAX-11/750 running 4.1BSD. An updated version, credited to Phil Betchel, Cliff Spencer, Gretchen Phillips, John LoVerso and Don Gworek, was posted to the net.sources Usenet newsgroup in December of 1985."
That said, while I don't believe there is any proof, I have always strongly believed that the name was a kind of geeky programmer joke. You have the command "su" (super user) "do" but you aren't actually a super user -- turn the "doo" into a "doh" and "sudo" looks/sounds a lot like "pseudo" (fake, sham).
-2
Most folks have given the answer that it's a mashup of "super user do". I like this, but it may be more correct to say that it's a mashup of "substitute user do" because you can choose what user you "do" as with the -u flag.
I also think of it as a play on the word psuedonym because you can pretend to be someone else , either root or any other user using the -u flag.
