I'm using Ubuntu Maverick (Gnome), a month ago I updated like usual whenever Update Manager informed me of new updates. The thing that happened is that a program called kdewallet got installed on my machine, and every time I try to do something that requires password like svn, it pops up and starts getting really annoying. How can I get rid of it? It's not even in the Synaptic Package Manager.
- 5,759
- 463
KDE Wallet is a core part of KDE, it's in the package kdebase-runtime.
To disable it run kcmshell4 kwalletconfig and continue at step 3 or start from the beginning:
- Start System setings
- Open Account Details
- Go to the "KDE Wallet" tab
- Uncheck Enable the KDE Wallet subsystem
- Click
Applyto apply the changes and close the settings window.
To get a list of the programs that depends on the kdebase-runtime package, run:
apt-cache --no-enhances --no-suggests --no-recommends --installed rdepends kdebase-runtime
On Ubuntu, the output shows just "kdebase-runtime [newline] Reverse Depends:". On Kubuntu, a whole list follows.
- 77,855
- 178,446
I got rid of the "KDE Wallet System" dialog (whenever I started Chrome) as follows:
Edit
~/.config/kwalletrc(see note below), and add[Wallet] Enabled=falseKill the kdewallet daemon:
pkill kdewallet5(orkillall kdewallet5)
I found this option when I looked through the source code (on kde.org or at the Github mirror).
If putting kwalletrc in ~/.config does not work, then your system probably uses a different directory for storing configuration files. The config file is created in a directory identified by QStandardPaths::GenericConfigLocation, so I used qtpaths to look up the path (~/.config = /home/rob/.config in my case):
$ qtpaths --paths GenericConfigLocation
/home/rob/.config:/etc/xdg
Note: if you don't want to completely disable kwallet, but only for Chrome, you can use the --password-store=basic flag as I explained at Disable kwallet popups from chrome. If you start Chrome via a wrapper script or shortcut, I recommend using --password-store=basic in case you need kwallet for something else. I disabled kwalletd instead of using this flag because I develop Chrome, and it's inconvenient to add this flag all the time when I run ./chrome.
(Tested on ArchLinux, but it should also work on Ubuntu. Use sudo apt-get install qttools5-dev-tools if you want to use qtpaths to find the configuration directory).
- 2,307
I executed:
- Start System settings.
- Go to the Advanced tab.
- Press KDE Wallet icon.
- Uncheck Enable the KDE Wallet subsystem.
OS: Ubuntu 10.04.4 LTS.
In Ubuntu 14.04 (trusty), step (2) is now "Go to Account Details"
- 832
- 265
Disable password required notification Kwallet
RESUME
KDE menu => system preferences => notifications => wallet (dropdown) => password required option => show popup (uncheck) => reboot.
DESCRIPTION
I'm spanish and maybe the options could have another translation.
I use KDE Plasma 5.12. Open the KDE menu and search "system preferences" and click on it. Now search for "notifications". At top right of the window you could see a dropdown, in my case, I had already choosen "accesibility" option, then change it and choose "wallet". The last step, click on "password required" option and uncheck show pop up or something similar (at bottom). Save and reboot, done :-).
Hope it helps and you can disable this annoying notifications.
- 559
