I've been trying to download Java Oracle 8 and WINE and I keep getting the same problem.
W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/Release Unable to find expected entry 'main/source/Sources' in Release file (Wrong sources.list entry or malformed file)
I get this when I try installing both and I've been searching for a solution, but I can't find one. Then there's this problem:
dpkg: error: failed to open package info file `/var/lib/dpkg/available' for reading: No such file or directory
What's that mean and ho do I fix it?
Ok, it doesn't show that error anymore, thank you to all of you. I really appreciate the help. I have a next question though...
You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: liboxideqtcore0 : Depends: oxideqt-codecs (= 1.0.0~bzr501-0ubuntu2) but it is not going to be installed or oxideqt-codecs-extra (= 1.0.0~bzr501-0ubuntu2) but it is not going to be installed wine1.7 : Depends: wine1.7-amd64 (= 1:1.7.19-0ubuntu2~trusty2) but it is not going to be installed Depends: binfmt-support (>= 1.1.2) but it is not going to be installed Depends: wine1.7-i386 (= 1:1.7.19-0ubuntu2~trusty2) but it is not installable Recommends: gnome-exe-thumbnailer but it is not going to be installed or kde-runtime but it is not going to be installed Recommends: ttf-mscorefonts-installer but it is not going to be installed Recommends: fonts-horai-umefont but it is not going to be installed Recommends: fonts-unfonts-core but it is not going to be installed Recommends: ttf-wqy-microhei Recommends: winetricks but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I did the command and it said something about /var/lib/dpkg/lock, so I go there and can't open the file. I am trying to install WINE 1.7 for Ubuntu 14.04 64-bit.
Seth
  • 59,332
this message means that you some broken URLs in packages list, you have to edit the list and remove those URLs, to do that open: /etc/apt/sources.list and save the file after editing it. then try to update again.
to understand apt-get command more follow http://manpages.ubuntu.com/manpages/saucy/en/man8/apt-get.8.html
Mohammad
  • 593
  • 17
-1
That error means you've screwed up the packages lists. Find the line in /etc/sources.list with dl.google.com on it and delete the whole line. Make sure to run sudo apt-get update afterwards, or it won't work.
figgyc
  • 99
