I have a new Lenovo Yoga 2 with Ubuntu 14.04. On every 3rd or 4th boot, the screen goes completely blank after the grub screen and the backlight seems to ramp up to maximum intensity (I see a faint growing white glow). I can hear the drums beat for the login, but nothing shows up on the screen. This seems to be random--I cannot figure out a way to bypass this without rebooting several times. It also seems to randomly happen while waking up from suspend.
I have the acpi_backlight = vendor in the grub boot line. This does not seem to make a difference as I get this random behaviour with and without the boot flag.
--prasanna
I have the same on 14.04. On 13.10 it worked well. I can't fix it, but there is a little workaround. When screen goes black press the F9 key (switch the screen off), close the lid and don't move the laptop*. It will go to sleep. Then open it and wake it up by pressing any key. My Yoga 2 Pro wakes up with the screen working fine.
  • Y2P has a movement sensor, so if you move it when it goes to sleep it fail to do so.
Pete
I have the same problem, also on 14.04 and I can't fix it either, but there is a simple work-around:
Just close the lid so the screen gets turned off and reopen it.
This seems to reset the graphic-card driver and the screen is working again (sometimes you have to do this several times to work).
I hope, I find out a cleaner solution, or a simpler workaround with just a Keyboard-shortcut to reset the graphic card driver
rubo77
  • 34,024
  • 52
  • 172
  • 299
I had this issue in the beginning too, but it seems to be fixed in Ubuntu 14.04 by now.
My Kernel: uname -rp
 3.14.1-031401-generic i686
rubo77
  • 34,024
  • 52
  • 172
  • 299
-1
If your screen acts strange after suspend, it's usually enough to switch to console (Ctrl+Alt+F1) and back to graphics again (Alt+F7).
Eliah Kagan
  • 119,640
Jaap
