How should I correctly install clang's c++ library (with STL) on my lubuntu machine? I want to use clang and its c++ library because it offers better support for the upcoming c++14 standard.
When trying to install libc++:
sudo apt-get install libc++
I get:
<!-- Fairly large amount of installed/up-to-date packages which I removed from the post-->
 libcgi-application-plugin-captcha-perl : Depends: libdata-random-perl but it is not going to be installed
 libcloog-isl-dev : Conflicts: libcloog-ppl-dev but 0.16.1-5 is to be installed
 libclutter-gst-2.0-doc : Conflicts: libclutter-gst-doc but 1.6.0-2build1 is to be installed
 libcuda1-304 : Conflicts: libcuda-5.0-1
 libcuda1-304-updates : Conflicts: libcuda-5.0-1
 libcuda1-331 : Breaks: libcuda-5.0-1
                Breaks: libcuda-5.5-1
 libcuda1-331-updates : Breaks: libcuda-5.0-1
 libcunit1-ncurses : Conflicts: libcunit1 but 2.1-2.dfsg-1 is to be installed
 libcunit1-ncurses-dev : Conflicts: libcunit1-dev but 2.1-2.dfsg-1 is to be installed
 libcurl4-gnutls-dev : Conflicts: libcurl4-nss-dev but 7.35.0-1ubuntu2 is to be installed
                       Conflicts: libcurl4-openssl-dev but 7.35.0-1ubuntu2 is to be installed
 libcurl4-nss-dev : Conflicts: libcurl4-gnutls-dev but 7.35.0-1ubuntu2 is to be installed
 libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.35.0-1ubuntu2 is to be installed
I am running lubuntu 14.04 on a Samsung Series 9 Ultrabook. I don't understand the conflicts, especially the ones related to CUDA, which is supposed to be only for systems with an NVidia GPU.
Please let me know what other information I need to provide.
EDIT:
After some trying around, I installed the libc++-dev package:
sudo apt-get install libc++-dev
This installed the header files which clang now finds and uses. This doesn't answer the original question of why apt-get attempted to install libc++ which apparently doesn't exist and why it got into conflicts (whith CUDA of all things!).
There is no package called libc++. It is libc++1.
So run the command as :
sudo apt-get install libc++1 multiarch-support libc6 libc++-dev libc++-helpers libc++-test libc++abi-dev libc++abi-test libc++abi1
Firstly type 'sudo apt-get -f install'. This will try to fix broken dependencies. If this ends up 'and x not upgraded', then type the following afterwards: 'sudo apt-get dist-upgrade'. This last command might install some new packages, so be careful.
Gx1sptDTDa
  • 1,663
  • 15
  • 24
The package libc++ doesn't exist. Most likely, apt-get is treating "libc++" as a regex and installing anything that matches that regex. Hence, you get the long list of packages to install.
The package you're (probably) looking for is libc++1.
saiarcot895
  • 10,917
