I've got a desktop with Ubuntu 7.10 installed, and I would like to use the old Firefox that comes with it and it's the only one working for certain online banking pages, and use the new Firefox 4 for newer HTML5 pages. How can I have both working side to side?
Thank you
This may be a solution to your problem: http://www.webupd8.org/2011/05/install-firefox-nightly-from-ubuntu-ppa.html
RobinJ
  • 9,020
I wouldn't be too surprised if you can't find a PPA, etc. to work with 7.10, because it relies on someone maintaining it.
You can download firefox yourself (www.firefox.com). You'll get a package which has already been compiled, and you can extract it to '/opt/firefox' and make a link to the executable.
Firefox can be a little funny with its dependencies, however, and you may find yourself needing extra libraries outside of the 7.10 repositories. In short, this could end up becoming quite involved; and I wouldn't attempt it if you're not too sure about the more detailed workings of Ubuntu.
Note that it will now be up to you to keep your browser updated, as you're outside the reach of aptitude, etc. and with something like a web browser, i recommend you keep an eye out for new versions.
From the requirements for Firefox 4:
Firefox will not run at all without the following libraries or packages:
    GTK+ 2.10 or higher
    GLib 2.12 or higher
    Pango 1.14 or higher
    X.Org 1.0 or higher (1.7 or higher is recommended)
    libstdc++ 4.3 or higher
Let's check these dependencies:
I'm surprised that it even works with such an old version. So, technically, you should be able to use Firefox 4. Follow the instructions on How to install Firefox 3.6 and 4.0 in parallel?
If you've the possibility, I suggest you to upgrade to the latest version (11.04 Natty) or the LTS 10.04 Lucid.
Lekensteyn
  • 178,446
