- Xubuntu 14.04
Hi,
first some code bits which I think are relevant:
$ sudo efibootmgr
BootCurrent: 0000
Timeout: 3 seconds
BootOrder: 0000,0003,0004
Boot0000* ubuntu
Boot0003* Hard Drive
Boot0004* CD/DVD Drive
$ sudo lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931,5G 0 disk
├─sda1 8:1 0 128M 0 part
├─sda2 8:2 0 157,7G 0 part
├─sda3 8:3 0 586,3G 0 part
├─sda4 8:4 0 30G 0 part /
├─sda5 8:5 0 157,3G 0 part /home
└─sda6 8:6 0 100M 0 part /boot/efi
sr0 11:0 1 1024M 0 rom
$ sudo blkid
/dev/sda2: UUID="C8C8DAE9C8DAD4B2" TYPE="ntfs"
/dev/sda3: LABEL="Data" UUID="9AE4BBDEE4BBBB39" TYPE="ntfs"
/dev/sda4: UUID="6ff82639-0387-4fe0-a9ea-d3d58b94358f" TYPE="ext4"
/dev/sda5: UUID="6e6e2000-fa00-4eda-a1eb-07f1b3fdd9e0" TYPE="ext4"
/dev/sda6: UUID="B0CD-A57E" TYPE="vfat"
john@xubuntubox:~$
Whenever I enter GRUB and boot into my Windows 7 installation, it adds itself to spot 0001 in the EFI menu and apparently gets set as the default boot target. So I have to enter the EFI settings on boot, select ubuntu for the GRUB menu and then can use Xubuntu again. So far so good. After a new sudo efibootmgr I usually run sudo efibootmgr -b 0001 -B to remove the Windows entry.
After a short while (can't say how long exactly), I always get a system error. Ubuntu keeps functioning fine though. Then when I choose to shut down via the Xfce GUI, the PC goes to the bootscreen, has the circle spinning and then the spinning suddenly stops. The fans are still running but the machine sounds like it's off otherwise.
How can I fix this?
However when I
