I''ve downloaded tar file from oracle server but I don't know how to install it on my ubuntu linux system. Could you please provide step by step details on how to install it? Thanks
Asked
Active
Viewed 1,470 times
If there is some trouble with installing downloaded files, try to get packages over the command line:
Open a new terminal.
Set this command:
sudo apt-get install icedtea–7-plugin openjdk–7-jre
Done.
samsy
- 71
You could just add a repository to your accepted sources. This is the one I used:
http://www.enqlu.com/2014/03/how-to-install-oracle-java-78-jdk-and.html
The site gives you step by step instructions. Simple and easy.
Bryan
- 3,642
Use following link and follow the given instructions:
http://www.liberiangeek.net/2012/04/install-oracle-java-jdk-7-in-ubuntu-12-04-precise-pangolin/
Prakash H
- 2,631
