57
I want to use ccache to speed up compilation.
I came across How do I enable ccache?.
This is what I have done so far:
$ sudo apt-get install -y ccache
$ dpkg -l ccache
ii  ccache  3.1.6-1   Compiler cache for fast recompilation of C/C++ code
$ whereis ccache
ccache: /usr/bin/ccache /usr/lib/ccache /usr/bin/X11/ccache /usr/share/man/man1/ccache.1.gz
I appended ccache to the path by adding it to my ~/.bashrc file:
$ export PATH="/usr/lib/ccache:$PATH"
$ source ~/.bashrc
$ echo $PATH
/usr/lib/ccache:/usr/local/cuda-5.5/bin/:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
The symbolic links look fine:
$ ll /usr/lib/ccache/
total 76
drwxr-xr-x   2 root root  4096 mai   22 10:48 ./
drwxr-xr-x 253 root root 69632 mai   22 10:48 ../
lrwxrwxrwx   1 root root    16 mai   22 10:48 avr-g++ -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 avr-gcc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 avr-gcc-4.5.3 -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 c++ -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 c89-gcc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 c99-gcc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 cc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 g++ -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 g++-4.6 -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 gcc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 gcc-4.6 -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 x86_64-linux-gnu-g++ -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 x86_64-linux-gnu-g++-4.6 -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 x86_64-linux-gnu-gcc -> ../../bin/ccache*
lrwxrwxrwx   1 root root    16 mai   22 10:48 x86_64-linux-gnu-gcc-4.6 -> ../../bin/ccache*
The link looks good:
$ which g++
/usr/lib/ccache/g++
$ make
g++ -o affine_euler affine_euler.cpp -O3 -DEIGEN_NO_DEBUG -I/usr/include/eigen3
g++ -o test_eigen test_eigen.cpp -O3 -DEIGEN_NO_DEBUG -I/usr/include/eigen3
But the cache is empty:
$ ccache -s
cache directory                     /home/dell/.ccache
cache hit (direct)                     0
cache hit (preprocessed)               0
cache miss                             0
files in cache                         0
cache size                             0 Kbytes
max cache size                       1.0 Gbytes
Where am I wrong?
Installation:
# Install package
sudo apt install -y ccache
# Update symlinks
sudo /usr/sbin/update-ccache-symlinks
# Prepend ccache into the PATH
echo 'export PATH="/usr/lib/ccache:$PATH"' | tee -a ~/.bashrc
# Source bashrc to test the new PATH
source ~/.bashrc && echo $PATH
Your path (at least the beginning) should look like:
And g++/gcc should now point to:
which g++ gcc
/usr/lib/ccache/g++
/usr/lib/ccache/gcc
Configuration:
If you want no limit to the number of files and size of the cache:
ccache -F 0
ccache -M 0
Show cache statistics:
ccache -s
Empty the cache and reset the stats:
ccache -C -z
Usage:
Every time you call gcc or g++; ccache is called. My mistake was that I didn't delete already-compiled files. Just delete all your CMake/output files and configure/compile again.
Your ccache shouldn't be empty then. Now try a make clean and make and you'll see it is much faster than re-compiling everything thanks to the cache.
Your $PATH doesn't look correct; ccache's directory should be in there. Just run:
export PATH="/usr/lib/ccache/:$PATH"
... and try your g++ commands again. This directory is full of proxy commands that call ccache. This should work with most scripts.
If you're just calling g++ manually (not like above where you're using make), you can just prepend the command:
ccache g++ ...
Oli
  • 299,380
Regarding installation:
I've found that on Ubuntu 18.04 (Bionic Beaver) the shipped default does not catch invocations of cc and c++. To fully install ccache there, you need:
sudo apt install ccache
And then (due to updated symlinks) also calls to cc and c++ get caught!
Pablo Bianchi
  • 17,371
