Which is the Desktop Environment of Zorin OS and is there any way to get it on Ubuntu?
Asked
Active
Viewed 5.5k times
16
Zorin OS use Gnome 3 Desktop Environment with customized themes. To install Gnome 3 use the following command:
sudo apt-get update && sudo apt-get install gnome-shell ubuntu-gnome-desktop
Then you need to get the themes from Zorin OS and apply to your Gnome installation. Since Zorin OS uses Ubuntu as base for it's packages it's simplier to install Zorin than to apply the themes to Ubuntu.
To install ZorinOS themes open Terminal (Press Ctrl+Alt+T) and type the following commands:
sudo add-apt-repository ppa:noobslab/themes
sudo apt-get update
sudo apt-get install zorinos-themes
To install ZorinOS icons open Terminal (Press Ctrl+Alt+T) type the following commands:
sudo add-apt-repository ppa:noobslab/icons2
sudo apt-get update
sudo apt-get install zorinos-icons
Just for the record: Zorin OS 12.2 Lite uses XFCE4.
//edit:
You can install it by writing in terminal:
sudo apt install xubuntu-desktop
Jozef Fekiač
- 11
