I'm a very new user to Ubuntu and everytime a boot with my usb stick I have to reinstall all the apps that I had previously downloaded. Why is this so?? How do I save everything so that I can just have it there ready for me to use?? Instead of downloading it each time?? I know that this seems like a silly question but I really could use some help.
Sam
You will have to recreate your boot stick. I tested this using UNetBootin. If you don't have it installed you will have to install it using Software Center (or by using sudo apt-get install unetbootin in terminal). In the lower part of the window you have to select the amount of space used to preserve settings and files across reboots (default is 0). Set this value to whatever suits you (depending also on the usb stick capacity, of course). Then, if everyting else is set click OK to create the disk.
Emil
  • 991
