< - - Linux Noob. I am normally on Raspberry, but the # symbol caused me to move my question here. Attempting to run a script, and failing, I found answers in Raspberry to use the following (preceded by the symbol #):
#!/usr/bin/env python
Link here describes my confusion. I thought # indicated a comment (in Linux and in Raspberry Python). I don't understand the # symbol at the beginning of the command prompt. #!/usr/bin/env python.
Question : Is the # symbol to be typed in?
I suspect the # symbol shows only because that otherwise the command would be executed.
Marla
  • 113
Yes, the # sign must be used. This is a special-case comment called a shebang line that causes the program specified (/usr/bin/env python in your case) to be run with the path to your program as an argument WikiPedia's page on Shebang is very good.
jkt123
  • 3,600
