30
There were a few ppa updates this morning, one of them was Caffeine. It was working fine initially, it does show up in the start up applications list but does not show up in the panel.
I tried removing it and installing it but that didn't do anything. I also figured it could have been my theme and icons, so I set it all to default to no avail.
I think it is Caffeine 2.7, not sure if I was on 2.6 or what. It was an official trusty ppa.
Anyone getting this issue?
I also noticed that Caffeine does function. I have my dim settings at 3 minutes, and when running a YT video in full screen it does not go to screen saver. And when left idle, it goes to screen saver.
JJD
  • 882
8 Answers8
32
The 2.7 release removes the user interface and manual operation. Caffeine is now fully automatic: When the active window is full screen, Caffeine inhibits desktop idleness.
This has been changed in version 2.8 (released January 15th, 2015), which has:
  • a caffeine program that works as v2.7: desktop idleness is prevented for full screen applications – fully automatic with no UI;
  • a caffeine-indicator program that works as v2.6 and earlier: an icon is shown in the panel that enables/disables desktop idleness;
  • a command caffeinate, that prevents desktop idleness for the duration of a command, e.g. caffeinate steam will prevent the screen saver while steam is running.
JW.
  • 1,396
Tomby
  • 344
As this answer states, Caffeine 2.6 and up is fully automatic depending on if your window is fullscreen. The developers removed the manual toggle in the menu bar.
A new fork made by mildmojo called Caffeine Plus brings the manual toggle with the icon in the menu bar back. You can install it manually with the .deb file or via PPA:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install caffeine-plus
Fallback to version 2.6 by using another ppa for now. A request to enable the toggle functionality has been made.
sudo apt-get purge caffeine && sudo apt-get autoremove
sudo add-apt-repository --remove ppa:caffeine-developers/ppa
sudo add-apt-repository ppa:behda/ppa
sudo apt-get update && sudo apt-get install caffeine
If it does not work then try following solution.
  1. Install Caffeine from behda ppa. This will resolve dependencies and configure/installs icons, shortcuts...
  2. Get the source file:
    tar -xzvf caffeine_2.6.2.tar.gz -C /path/to/preferred/dir
  3. Test:
    cd /path/to/caffeine/dir
    ./bin/caffeine
  4. Change startup executable on /usr/share/applications/caffeine.desktop
d a i s y
  • 5,551
vmoreno
  • 51
As stated by @tomby, the GUI was removed in 2.7.
An option is download the 2.5 version here
Install the required packages:
sudo apt-get install gir1.2-gtk-2.0 libsqlite0 python-kaa-base python-kaa-metadata python-sqlite
Then install the .deb file:
sudo dpkg -i caffeine_2.5_all.deb
d a i s y
  • 5,551
Thanks @user10962 ! Your post help me to correct this issue. I definitively uninstall caffeine and replace it by a small script which is runned at startup. You must create before an empty file /usr/sbin/pm-hibernate.gmev.sh (with same right as pm-hibernate) and give rights in your sudoers file to your user to do /bin/mv and /bin/cp as root. It verifies (each minute) if vlc or flashplugin is used before disable screensaver (or blank screen) and hibernate :
#!/bin/sh
sudo /bin/mv /usr/sbin/pm-hibernate_unactived_by_gmev.sh /usr/sbin/pm-hibernate 2> /dev/null
while [ 1 ]
 do
  xset q | grep "DPMS is Disabled" > /dev/null
  rc=`echo $?`
  ps -ef | grep flashplugin | grep -v grep > /dev/null
  rc2=`echo $?`
  ps -ef | grep vlc | grep -v grep > /dev/null
  rc3=`echo $?`
  if  [ $rc2 -eq 0 ] || [ $rc3 -eq 0 ]
   then
    if [ $rc -ne 0 ]
     then
      sudo /bin/mv /usr/sbin/pm-hibernate /usr/sbin/pm-hibernate_unactived_by_gmev.sh
      sudo /bin/cp -p /usr/sbin/pm-hibernate.gmev.sh /usr/sbin/pm-hibernate
      xset s off -dpms
     fi
   else
    if [ $rc -eq 0 ]
      then
      xset s on
      xset dpms 600 0 900
    fi
  fi
 sleep 60
done
JJD
  • 882
Eddy
This bugged me too so I've written a new caffeine application from scratch:
Caffeine screenshot
Installation
First make sure to remove the other caffeine if you have installed it:
sudo apt-get remove caffeine --purge
sudo add-apt-repository --remove ppa:behda/ppa
Now you can install:
sudo add-apt-repository ppa:kzar/caffeine
nohup caffeine &
Feedback + contributions welcome! https://github.com/kzar/caffeine
kzar
  • 199
For those simply looking for a way to disable the default "sleep/suspend/hibernate after a given amount of time" routine (as is possible with the Caffeine applications on OSX and Windows), I found the following terminal commands do the trick nicely:
# Turn off screensaver
xset s off
# Turn off sleep
xset s noblank
# Turn off suspend, hibernate, etc
xset -dpms
I recommend running these once and seeing if you like the result, then adding these to .xinitrc (or similar) so they're run by default at startup.
user10962
  • 2,619
FWIW, I've added a comment to this bug, I would recommend anyone else who is just as annoyed by the recent change to weigh in.
Who knows, we may get back the old, sane behavior :)
For now, as suggested by Rael, installing 2.5 seems to be the only solution.
