24
I try to repair an broken Ubunu 14.04 with chroot. What I did, is to boot Ubuntu from USB mounted the original system that has to be repaired and changed to this system with chroot:
sudo mount /dev/sdXY /mnt
sudo mount -o bind /dev /mnt/dev
sudo mount -o bind /sys /mnt/sys
sudo mount -t proc /proc /mnt/proc
sudo cp /proc/mounts /mnt/etc/mtab
sudo chroot /mnt /bin/bash
That worked fine, but in chroot environment I don't have access to the internet, so apt isn't able to resolve hostnames. What am I supposed to do?
ping www.askubuntu.com
does not work either.
user5950
  • 6,406
On newer Ubuntu systems, name resolution is handled by the resolvconf service, and /etc/resolv.conf is a symbolic link to /run/resolvconf/resolv.conf. You can either add a bind mount to the /run filesystem along with your other bind mounts before executing the chroot command
sudo mount -o bind /run /mnt/run
so that the chroot system picks up the host system's DNS settings or, once you're in the chrooted system, temporarily create a static /etc/resolv.conf with nameserver(s) of your choice e.g.
echo 'nameserver 8.8.4.4' | sudo tee -a /etc/resolv.conf
steeldriver
  • 142,475
