Due to the unusual way my ISP set up Internet, I need to manually set up MAC address to go online. So far I've been using:
sudo ifconfig eth0 down
sudo ifconfig eth0 hw ether  xx:xx:xx:xx:xx:xx
sudo ifconfig eth0 up
However, I have to enter this command every time I start my computer. How to set MAC address permanently?
You can use an udev rule to automatically set the MAC address on your network interface
Create the file /etc/udev/rules.d/99-custom-mac.rules and paste into it:
ACTION=="add", SUBSYSTEM=="net", ATTR{address}=="XX:XX:XX:XX:XX:XX", RUN+="/sbin/ip link set dev %k address YY:YY:YY:YY:YY:YY"
where XX:XX:XX:XX:XX:XX is the original MAC address of your interface (you can get it in the output of ip link) and YY:YY:YY:YY:YY:YY is the new MAC address you want to enforce.
To make the change effective you can run
sudo udevadm control --reload
but I doubt it works, so a reboot might be necessary.
solsTiCe
  • 9,515
you can make a shell script with this commands:
Save the file with .sh extension and make it startup program ("Add Script" and select your script file)
Tell me how it was ?
Sorry for my bad english.
midway
Copy all the matter in the terminal
sudo ifconfig eth0 down && sudo ifconfig eth0 hw ether 00:4a:82:d5:e4:c6 && sudo ifconfig eth0 up
