I am new to the Valgrind tool and I am using my cross compiled valgrind with ARM target board to run my executable. While executing the cachegrind tool with my executable it successfully generating the cachegrind.out.PID file as like below
] /opt/valgrind/bin/valgrind --tool=cachegrind ./w-rpc
file that generated out of it is in the name of cachegrind.out.29271.
Since my target board doesn't have perl support, I could not able to run cg_annotate in my target board. So I am running this cg_annotate file with this cachegrind.out.29271 at my ubuntu machine. But every time it is showing this below information only. I cannot see the detailed source code analysis information, is that problem of version mismatch or anything I am missing here. Please suggest me a solution for this, I am really blocked on this situation and tried almost all possible solution which is available on the valgrind documentation.
below is the information that i could able to see from the cachegrind.out.29271 file and at the end of this report it saying "No information has been collected for /home/radhar/myshare/PB_Test/c_RPCMonitor.cc ",please see the below
$ cg_annotate cachegrind.out.29271 /home/radhar/myshare/PB_Test/c_RPCMonitor.cc
I1 cache: 16384 B, 64 B, 4-way associative
D1 cache: 16384 B, 64 B, 4-way associative
LL cache: 262144 B, 64 B, 8-way associative
Command: ./w-rpc_exit
Data file: cachegrind.out.29271
Events recorded: Ir I1mr ILmr Dr D1mr DLmr Dw D1mw DLmw
Events shown: Ir I1mr ILmr Dr D1mr DLmr Dw D1mw DLmw
Event sort order: Ir I1mr ILmr Dr D1mr DLmr Dw D1mw DLmw
Thresholds: 99 0 0 0 0 0 0 0 0
Include dirs:
User annotated: /home/radhar/myshare/PB_Test/c_RPCMonitor.cc
Auto-annotation: off
38,385,638 14,462 4,450 5,369,475 159,757 63,018 1,424,411 2,155 1,337 PROGRAM TOTALS
Ir I1mr ILmr Dr D1mr DLmr Dw D1mw DLmw file:function
26,263,438 238 23 1,398,703 59,346 15,533 237,160 30 13 ???:_dl_lookup_hash
9,128,805 6,745 2,174 2,919,360 92,571 43,596 511,921 776 396 ???:???
320,759 58 12 105,071 108 0 72,599 2 0 ???:pthread_mutex_unlock
293,044 493 10 91,275 252 13 86,395 26 3 ???:pthread_mutex_lock
232,047 33 2 122,130 47 0 36,639 0 0 ???:OMTimerManager::lock() const
232,028 27 2 122,120 0 0 36,636 0 0 ???:OMTimerManager::unlock() const
185,511 24 2 68,015 37 2 68,018 0 0 ???:pthread_setcanceltype
164,862 88 4 48,848 0 0 24,424 0 0 ???:OMTimerManager::post()
146,544 47 3 73,272 0 0 24,424 0 0 ???:OMTimerManager::timeTickCbk()
134,355 73 5 67,171 18 0 61,074 0 0 ???:nanosleep
122,150 14 0 36,645 0 0 36,645 0 0 ???:LinuxMutex::unlock()
122,150 12 1 36,645 0 0 36,645 0 0 ???:LinuxMutex::lock()
100,373 41 40 3,903 15 10 16,463 235 234 ???:_dl_load_elf_shared_library
97,252 875 55 28,280 566 37 12,461 518 371 ???:malloc
91,605 25 3 24,426 31 0 3 0 0 ???:LinuxTimer::waitThread()
79,391 35 2 18,321 0 0 12,214 0 0 ???:OMUHeap::isEmpty() const
67,166 37 1 30,530 50 2 6,106 0 0 ???:OMThread::isEndOfProcess()
55,240 0 0 0 0 0 13,810 1 0 ???:__pthread_unlock
54,954 37 2 18,318 0 0 18,318 0 0 ???:OMTimerManager::cbkBridge(void*)
35,557 6 6 11,905 2,079 2,050 5,948 5 5 ???:_dl_fixup
27,620 17 6 0 0 0 0 0 0 ???:__pthread_lock
26,996 4 2 14,292 0 0 9,528 2 0 ???:_pthread_cleanup_pop_restore
25,552 162 18 12,865 117 16 7,883 8 0 ???:free
User-annotated source: /home/radhar/myshare/PB_Test/c_RPCMonitor.cc
Exactly I need to see the detailed analysis report of the source file (which consists of many functions)...?
Thanks In advance for your time and help,
Ratheesh
