17
In Ubuntu 12 LTS, I always used mount.cifs and mount.nfs
Now they are not in the Ubuntu 14.04 repository, so how do you use mount cifs and mount nfs or install them in 14?
Thanks
i.e.)
Ubuntu 12.04 always worked with:
 root@ub12box# mount -t cifs -o user=administrator '\\192.168.0.1\Data' /tmp/myServer ; df ;
 Password: ***************
 Filesystem                1K-blocks      Used Available Use% Mounted
 on /dev/sdb2                 144636 85800  26058836  8% /
 \\192.168.0.1\Data 8059772 652288 407484  6% /tmp/myServer
But doesnt work in Ubuntu 14.04 machine same command:
root@ub14box# mount -t cifs -o user=administrator '\\192.168.0.1\Data' /tmp/myServer ; df ;
mount: block device \\192.168.0.1\Data is write-protected, mounting read-only
mount: cannot mount block device \\192.168.0.1\Data read-only
on /dev/sdb2                 126636 950900  99958936  2% /
root@ub14box# dmesg|tail
[ 2023.664186] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 2023.664197] CIFS VFS: Send error in SessSetup = -13
[ 2023.667124] CIFS VFS: cifs_mount failed w/return code = -13
[ 2023.676417] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 2023.676424] CIFS VFS: Send error in SessSetup = -13
[ 2023.676499] CIFS VFS: cifs_mount failed w/return code = -13
Bran
  • 795
  • 19
The mount.cifs command is provided by cifs-utils and mount.nfs by nfs-common.
In general, when you're looking for a particular file and don't know which package provides it, you can search in the Ubuntu Repositories or in synaptic. Alternatively, you can use apt-file.
If it is not installed, install it with sudo apt-get install apt-file and then update its database with apt-file update. Once you've done that, you can easily search package contents:
$ apt-file search mount.cifs mount.nfs
cifs-utils: /sbin/mount.cifs
cifs-utils: /usr/share/man/man8/mount.cifs.8.gz
$ apt-file search mount.nfs
manpages-fr-extra: /usr/share/man/fr/man8/mount.nfs.8.gz
manpages-fr-extra: /usr/share/man/fr/man8/umount.nfs.8.gz
nfs-common: /sbin/mount.nfs
nfs-common: /sbin/mount.nfs4
nfs-common: /sbin/umount.nfs
nfs-common: /sbin/umount.nfs4
nfs-common: /usr/share/man/man8/mount.nfs.8.gz
nfs-common: /usr/share/man/man8/umount.nfs.8.gz
terdon
  • 104,119
